Google Assistant Voice Commands
Control your Wyze devices with your voice by pairing them with Google Home Assistant and using the voice commands below.
Wyze Cam
With the Google Nest Hub you can view live activity from Wyze Cam v2 and Wyze Cam Pan.
Say "OK Google" or "Hey Google," then:
  • “Show me <camera name> on <casting device name>”
  • “Show my <camera name> on <casting device name>”
  • “Show the <camera name> on <casting device name>”
  • “Show <camera name> on <casting device name>”
Note: These commands only work with Google Home devices with a screen.
Wyze Bulb:
Wyze Bulb too dim? Cool? Just want to turn it off? Say "OK Google" or "Hey Google," then:
  • "Turn on <bulb name>"
  • "Turn off <bulb name>"
  • "Brighten the <bulb name>"
  • "Set <bulb name> to 50%" (scale of 1-100%)
  • "Dim <bulb name> by 50%" (scale of 1-100%)
  • "Brighten <bulb name> by 50%" (scale of 1-100%)
  • "Set <bulb name> to <color temperature>"*
*Color temperature commands (from warmest to coolest):
Candlelight,  Incandescent, Warm White, Cool White, Daylight, and Ivory
Wyze Plug
You can use voice commands to turn on or off a specific Wyze Plug. Say "OK Google" or "Hey Google," then:
  • "Turn on <plug name>"
  • "Turn off <plug name>"
Wyze Sense
You can use voice commands to turn on or off a specific Wyze Sense sensor. Say "OK Google" or "Hey Google," then:
  • "Turn <sensor name> on"
  • "Turn <sensor name> off"
