Google Assistant FAQ
Which Wyze products work with Google Assistant (Google Home)?
These Wyze products work with Google Assistant: Wyze Cam v2, Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam Pan, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Cam Floodlight v2, Wyze Lock, Wyze Plug, Wyze Bulb, and Wyze Sense Contact Sensors.
Note: Wyze Sense Motion Sensor is not compatible with Google Assistant.
Is Wyze Cam v1 compatible with Google Home?
No. Due to hardware limitations, the Google Assistant integration is not available on Wyze Cam v1.
How can I view a live stream on Google Hub?
Say "Hey Google". Then “Show me <camera name> on <casting device name>”. You'll be able to view a live stream from your Wyze Cam v2, Wyze Cam Pan, or Wyze Cam Pan v3.
Note: Viewing a live stream is only available on Google Home devices with a screen (ex. Google Hub).
