Which Wyze devices are compatible with Google Assistant?
These devices are compatible with Google Assistant:
Cameras
  • Wyze Cam Pan
  • Wyze Cam Pan v2
  • Wyze Cam Pan v3
  • Wyze Video Doorbell v1
  • Wyze Video Doorbell v2
Smart Home and Security
  • Wyze Lock
  • Wyze Thermostat
  • Wyze Sprinkler Controller
Power and Lighting
  • Wyze Bulb
  • Wyze Bulb Color
  • Wyze Light Strip
  • Wyze Light Strip Pro
  • Wyze Plug
  • Wyze Plug Outdoor
Sensors
  • Wyze Sense v1
Google Devices
The Wyze devices listed above are compatible with the following Google devices:
  • Any display with a standalone Chromecast plugged in.
  • Any smart display with built-in Chromecast.
  • Google Nest Hub (formerly Google Home Hub).
Note: Want to view your camera’s live stream on your Google device? You'll need an Google Nest Hub or a Chromecast enabled-device with a screen.
