Cam Plus Setup Guide
Ready to get set up with Cam Plus? You're in the right place.
To sign up for Cam Plus on the Wyze website:
  1. Go to https://my.wyze.com/account/plans.
  2. Click or tap Subscribe Now under Cam Plus.
  3. Select the plan you want and click or tap Add to Cart. Select Cam Plus Plan.png
  4. Check out using the email address that you use to log in to your Wyze app.
    • This is important so your plan is attached to the right account!
  5. Continue to payment, add your payment method, and select Pay now.
  6. You're all set! Now that you're signed up, head to the Wyze app to confirm that the subscription is assigned to your devices.
Note: You can purchase up to 3 Cam Plus licenses on one account.
To enable Cam Plus in the Wyze app:
  1. In the app, you'll get a “New Subscription Available” popup. Tap Finish Setup.
  2. Select Add Camera > Select Device.
  3. Your changes will save automatically.
Note: Find all of your active Cam Plus subscriptions in the Wyze app under Account > Services > Cam Plus.
