Most Wyze Cams are compatible with all Wyze Security Plans, but there are a few exceptions. Check out the table below for your Wyze Cam compatibility.
| Camera | Cam Plus | Cam Unlimited | Cam Unlimited Pro | Wyze Home Monitoring |
| Wyze Cam v4 | Yes | Yes | Yes | No |
| Wyze Cam v3 Pro | Yes | Yes | Yes | Yes |
| Wyze Cam v3 | Yes | Yes | Yes | Yes |
| Wyze Cam v2 | Yes | Yes | Yes | Yes |
| Wyze Cam v1 | No | No | No | No |
| Wyze Solar Cam Pan | Yes | Yes | Yes | Yes |
| Wyze Duo Cam Pan | Yes | Yes | Yes | No |
| Wyze Cam Pan v4 | Yes | Yes | Yes | Yes |
| Wyze Cam Pan v3 | Yes | Yes | Yes | Yes |
| Wyze Cam Pan v2 | Yes | Yes | Yes | Yes |
| Wyze Cam Pan | Yes | Yes | Yes | Yes |
| Wyze Cam Floodlight v2 | Yes | Yes | Yes | Yes |
| Wyze Cam Floodlight Pro | Yes | Yes | Yes | No |
| Wyze Cam Floodlight v1 | Yes | Yes | Yes | Yes |
| Wyze Cam OG | Yes | Yes | Yes | Yes |
| Wyze Cam OG Telephoto 3x | Yes | Yes | Yes | Yes |
| Wyze Duo Cam Doorbell | Yes | Yes | Yes | No |
| Wyze Video Doorbell v2 | Yes | Yes | Yes | Yes |
| Wyze Video Doorbell Pro | Yes | Yes | Yes | Yes |
| Wyze Video Doorbell | Yes | Yes* | No | Yes |
| Wyze Battery Cam Pro | Yes | Yes | Yes | No |
| Wyze Cam Outdoor v2 | Yes | Yes* | No | No |
| Wyze Cam Outdoor | Yes | Yes* | No | No |
| Wyze Bulb Cam | Yes | Yes | Yes | No |
| Wyze Window Cam | Yes | Yes | Yes | Yes |
*Wyze Cams that do not support the Monitoring tab on a Cam Unlimited security plan are: Wyze Cam Outdoor, Wyze Cam Outdoor v2, and Wyze Video Doorbell.
