Wyze Intelligence: Advanced Vehicle Detection
What is Advanced Vehicle Detection?
Advanced Vehicle Detection is an AI-powered feature that identifies and tags service vehicles captured on your compatible Wyze Cam.
How do I set up Advanced Vehicle Detection?
You must have an active subscription to Cam Plus, Cam Unlimited, or Cam Unlimited Pro, and the latest version of the Wyze app (v3.23+). To get this feature, enable Vehicle Detection in your camera's settings.
  1. Update your Wyze app to version 3.23+.
  2. In the Wyze app, tap on your compatible* Wyze Cam.
  3. Tap Settings > Event Recording > Customize Detections.
  4. Next to Vehicle, check the boxes to Tag and Notify.
Which Wyze Cams are compatible with Advanced Vehicle Detection?*
Advanced Vehicle Detection is compatible with:
  • Wyze Battery Video Doorbell
  • Wyze Cam v2
  • Wyze Cam v3
  • Wyze Cam v4
  • Wyze Cam Pan v2
  • Wyze Cam Pan v3
  • Wyze Cam Floodlight v1
  • Wyze Cam Floodlight v2
What if I have a mix of compatible and incompatible Wyze Cams?
You'll continue to get generic "Vehicle Detected" notifications on the incompatible Wyze Cams.
What types of service vehicles will be detected?
Delivery
  • Amazon
  • DHL
  • FedEx
  • UPS
  • USPS
Emergency
  • Ambulance
  • Fire Truck
Service
  • School Bus
  • Trash Truck
Does Advanced Vehicle Detection identify police vehicles?
No, not at this time.
Can I search for specific vehicle types?
Yes! Event filters and Video Search can be used to search for specific service vehicles.
Why wasn't a vehicle identified correctly?
This can happen due to various factors including camera angle, obstructions, glare, or lighting conditions. In these instances, the vehicle may be labeled with the generic "Vehicle Detected" tag.
Can shared users see the new tags?
Yes, if the shared device is compatible with Advanced Vehicle Detection.
