Wyze Cam v3 Setup Guide
Before you begin setup:
  3. Unpack your Wyze Cam v3 box, removing all plastic and packing materials.
  4. Plug the camera into power using the included USB cable and power adapter.
    • The camera’s status light will turn solid red when powered. When flashing, it’s ready for setup.
To set up your Wyze Cam v3:
  1. In the Wyze app, tap on the Home tab, then tap the + plus sign on the top left.
  2. Tap Add Device.
  3. Tap Cameras > Wyze Cam v3 > Begin setup.
  5. Pull the base from your camera and single-press SETUP under the camera until it says “ready to connect”.
  6. In the app, check the box next to “I heard, ‘Ready to connect’”.
  7. Tap Next.
  8. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  9. Scan the QR code on the Wyze app.
    • Hold your camera up to your phone screen with the QR code displaying. It will say “QR code scanned, please wait” then “setup completed”.
  10. In the app, check the box next to “I heard, ‘QR code scanned’”.
  11. Tap Next. You’re set up, it’s time to name your device.
  12. Name your Wyze Cam v3 using the text field, or by choosing a suggestion.
  13. Tap Finish when done.
Additional Notes:
  • Most Wyze devices only work on 2.4 GHz Wi-Fi networks. If you are connected to a 5 GHz network, switch to a 2.4 GHz network before setting up your device.
  • Having trouble scanning your QR code? A few tips to help:
    • Hold your camera 6-10 inches away from your phone screen.
    • Slowly move the QR code on the screen away from the camera, then closer.
    • Tilt your phone screen slightly in case there's a glare.
    • Turn your phone upside down.
    • If you're on iOS, turn off "Invert Colors".
    • Make sure the QR code isn't distorted.
      • If you have an older device, the screen may be too small. Try a different device.
      • If your screen is cracked or scratched, the code may be distorted. Try a different device.
      • If you're using a beta version of the Wyze app, make sure the cursor is not on the QR code.
Still need help?
