How to update your Wyze Cam v3 firmware
It is important to keep your camera’s firmware up to date so that it can function properly and enable new features as they are released.
To update your Wyze Cam v3 firmware:
  1. In the Wyze app, tap on your Wyze Cam v3, then the settings gear.
  2. In your v3 Settings, tap Device Info > Upgrade.
    • Don't see Upgrade? Then your firmware is already up to date!
Another option, go to Account > Firmware Upgrade. Here you will be able to see if you have the newest version. You also have the option to Upgrade All if a new firmware version is available.
