Wyze Sprinkler replaces the controller of your existing irrigation system. Refer to the Compatibility Guide below to see if your system will work with Wyze Sprinkler.
System Compatibility |
Number of Supported Zones |
Up to 8 zones |
Master Valve |
Yes, compatible |
Pump |
Yes, with pump relay. Do NOT connect a pump directly to the device. |
Indexing Valve |
Limited Function. Learn More |
3rd Party Rain & Soil Sensors |
Wired & Wireless Normally Closed (NC) rain/soil sensors |
Wire Gauge |
28-12 AWG |
Brand Compatibility |
| Brand | Sensor Type | Wired/Wireless | Support Model |
| Rain Bird | Rain Sensor | Wired | RSD |
| Rain Sensor | Wireless | WR2 | |
| Smart Y Soil Sensor | Wireless | SMRT-Y | |
| Toro | Rain Sensor | Wired | TRS, 53769, 53853 |
| Rain Sensor | Wireless | TWRS | |
| Soil Sensor | Wireless | PSS-SEN | |
| Hunter |
Rain Sensor |
Wired | MINI-CLIK |
| Rain Sensor | Wireless | RAIN-CLIK | |
| Orbit | Rain Sensor | Wired | 57069 |
| Rain Sensor | Wireless | 57071 | |
| Irritrol | Rain Sensor | Wired | RS500 |
| Rain Sensor | Wireless | RS1000 | |
Additional Note:
Wyze Sprinkler is not a standalone device, is not an irrigation system, and it cannot be used as a timer that attaches directly to a hose. It works similarly to how Wyze Thermostat replaces your existing thermostat, and how Wyze Video Doorbell replaces your existing wired doorbell.
