Fixed Schedules
Create schedules to water plants on specific days and times.
There are 3 types of schedules: Smart, Offline, and Fixed. Fixed schedules are defined and regular.
With a Fixed Schedule, you can choose to water on specific days of the week or on even/odd days. You can even set a start or end time, and can customize how long to water each zone.
With Sprinkler Plus you can also have your fixed schedule skip waterings based on weather conditions.
To create a Fixed Schedule, tap on your Wyze Sprinkler in the app, then tap Settings icon. Next, tap on Schedule. Under “ONLINE”, tap Create Schedule, then Fixed Schedule.
