Quick Runs on Wyze Sprinkler
Give your plants a little extra water with a Quick Run.
If you ever want to give your plants a little extra water you can do so easily with a Quick Run.
To start a Quick Run:
  1. In the Wyze app, tap on your Wyze Sprinkler.
  2. Tap on the water icon.
  3. Select the zone(s) you want to water and how long you want to water them for.
  4. Tap Save.
