Cycle/Soak
Let your lawn soak it all in.
If you water a zone for too long, some of the water may run off and be wasted. The Cycle/Soak feature breaks your watering down to multiple cycles giving the soil time to soak the water in for better efficiency.
The cycle time is decided by the spray head type, soil type, and slope while the soak time is 30 minutes.
While a zone is “soaking,” Wyze Sprinkler will stop all watering to allow zones to soak. This time is added to the total watering time listed.
