Shortcuts on your Wyze Watch
Shortcuts allow you to perform multiple actions with your Wyze devices at once.
Leaving the house? You can create a shortcut to turn off the lights and lock your Wyze Lock from a tap in the Wyze app. Manage your shortcuts with a tap on your Wyze Watch.
To set up Shortcuts for your watch:
  1. In the Wyze app, tap Wyze Watch.
  2. Under the Apps section of the page, tap Shortcuts.
  3. Any shortcuts you've created will display here. Select them by tapping the + plus sign to the left of each shortcut.
  4. When done, tap Save.
To use Shortcuts on your Watch:
Tap on the Wyze Watch screen to wake it up, then swipe left to access the Apps screen. Tap the star-shaped icon to access Shortcuts. Scroll through the listed Shortcuts if needed, then tap one to use it.
To remove Shortcuts from your Watch:
  3. Tap the - delete sign to the left the Shortcuts you want to remove.
Additional Notes:
  • A maximum of 10 Shortcuts can be added to Wyze Watch.
  • Create a shortcut from the Shortcuts screen above by tapping Create a new Shortcut. For more details about creating shortcuts, please reference this article.
