Custom Watch Faces
The Watch has a customizable home screen displaying a watch face, along with various built-in designs, and the ability for users to customize further with a picture background.
To change the watch face on the watch itself:
  1. Swipe right-to-left then tap Settings.
  2. Tap Change Wallpaper.
  3. Select one of the 3 options available on the Watch.
  4. Tap the screen to finalize the selection.
To change the options that show up on the Watch, you have to adjust the listings via the Wyze app while the Watch is paired.
To change your watch face options:
  1. In the Wyze app, tap on your Wyze Watch.
  2. Tap Edit next to Clock Face.
    1. If 6 faces are already listed, you’ll have to remove 1 of them by tapping the [...] in the top right.
    2. Next, tap the - icon to the left of the one you want to remove.
  3. Under Recommended Faces, tap one of the existing options, then Add.
    • Want to create custom watch face?
      1. Scroll to Photos and tap any watch face.
      2. Tap the + plus sign and follow the on-screen instructions upload a photo from your device.
      3. Use the Crop screen to fine-tune the size and position of the image.
      4. Tap OK to save your new watch face.
