Wyze Cam v3 shows as offline but the live stream works.
Problem
Your Wyze Cam v3 shows an offline symbol in your device list. You can still tap and view the live stream, however.
Troubleshooting
  1. Power cycle your Wyze Cam v3.
    1. Unplug the camera from its power source.
    2. Wait 5-10 seconds.
    3. Plug the camera back into power and allow it reinitialize.
    4. You should see the ON symbol next to the camera in the app.
  2. Next, update your Wyze Cam v3 firmware.
    • In the Wyze app, tap Account > Firmware Upgrade to see if you have the option to upgrade your camera. If not, you're all set.
