Wyze Cam v3 "cannot find the specified network name"
Problem
When trying to connect your Wyze Cam v3 to your Wi-Fi network, you get this error message.
Troubleshooting
This error message occurs when either the password entered for the network is incorrect or Wyze Cam v3 is attempting to connect to a 5 GHz network instead of a 2.4 GHz network.
  1. Confirm that your network name is entered correctly (passwords are case sensitive). You can check the password by tapping on the eyelashes, which should show you the password entered.
  2. Check to make sure your network name doesn't have a space at the beginning or end. If it does, you can either change this in your router's settings or reach out to your ISP to have the space removed from the name.
    • Example: "Wyze Network123   " won't work, but "Wyze Network123" will.
    • Similarly, "   Wyze Network123" won't work, but "Wyze Network123" will.
  3. Make sure you are attempting to connect to a 2.4 GHz network and not a 5 GHz network.
    • If you have two wireless networks, pick the one that does not have 5G on it.iPhone Wi-Fi networks
    • Make sure the network you pick does not have "5G," "5g," 5GHz," or "5" at the end.
  4. If your network only has one network name (SSID), it likely either only has a 2.4 GHz network or will shift traffic to the proper channel during setup.
  5. Try to reset your connection on your phone or tablet by forgetting the network on your iOS or Android device, restart the device, and attempt setup again.
