My handheld vacuum is loud or extra noisy.
Problem
Your Wyze Handheld Vacuum sounds abnormally loud, noisy, or making strange sounds.
Troubleshooting Tips
  1. Check the nozzle, the front end of the vacuum.
    • If the nozzle is blocked, the vacuum will be loud or noisy while cleaning.
  2. Check if the HEPA filter and prefilter are fully in place.
    • If either filter is not firmly in place before reassembling the vacuum, it can cause noisiness.
  3. Empty the dust cup.
    • If the dust cup is too full, the vacuum will be loud while cleaning.
