How do I factory reset my Wyze Duo Cam Pan?
To factory reset Wyze Duo Cam Pan:
  1. Remove any microSD card that is inserted into the camera.
  2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
  3. Once the status light starts flashing red, set up the camera as new.
Note: When Wyze Duo Cam Pan resets, it will rotate while initializing.
