My Wyze Duo Cam Pan is missing or not recording Events.
Problem
Wyze Duo Cam Pan is not recording any motion-triggered events, is missing events, or is not sending me any notifications.
Note: An active subscription to a Wyze Service is required to receive cloud Event videos.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Duo Cam Pan’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  4. Ensure the camera is set to record correctly.
    1. In the Wyze app, navigate to the camera’s settings > Event Recording.
    2. Enable Motion, then select All Events.
    3. Tap Customize Detections.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
    5. Attempt to trigger the camera by creating movement in front of the device.
    6. Note: For Wyze Services users, once recordings for Other Motion are being generated, you can select the desired AI recordings by checking the other options in the Tag and Notify columns.
  5. Verify that the Detection Settings are set correctly.
    1. Navigate to the camera’s settings > Detection Settings.
    2. Select Pan Cam.
    3. Under Motion Detection Sensitivity, adjust the slider bar to High.
    4. Tap Detection Zone and toggle it off while testing.
    5. Select Fixed Cam, and repeat the process.
  6. Check that Notifications are set correctly.
    • For the camera:
      1. Navigate to the camera’s settings > Notifications.
      2. Enable Notifications.
      3. Note: Tap Event Recording to be taken back to the screen to customize the Notify column for your recordings.
    • For the Wyze app:
      1. Navigate to the Home tab of the Wyze app.
      2. Tap Account > Notifications > Push Notifications.
      3. Toggle on Push Notifications.
    • For your mobile device:
      1. Navigate to your device’s settings.
      2. Enable notifications for the Wyze app.
  7. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  8. Power cycle Wyze Duo Cam Pan.
    1. Unplug the camera from its power source for 5-10 seconds, then plug it back in.
  9. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera as new.
