My Wyze Duo Cam Pan is moving by itself.
Problem
My Wyze Duo Cam Pan is rotating by itself – I’m not doing anything or changing any settings.
Note: When Wyze Duo Cam Pan resets, it will rotate while initializing.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Duo Cam Pan’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure the camera’s power cable and adapter are fully and securely inserted into the camera and the power source.
  4. Try a different power cable, adapter, or outlet.
    • If the camera is not getting enough or consistent power, it may be resetting.
  5. Turn off Track Motion.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Track Motion.
    2. Tap to turn it on/off.
      • The icon will be grey when turned off.
  6. Turn off Pan Scan.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Pan Scan.
  7. Disable any Detection Zone.
    1. In the camera’s settings, tap Detection Settings > Pan Cam > Detection Zone.
    2. Toggle off Detection Zone.
    3. Note: If you adjust your camera’s view while a Detection Zone is enabled, the camera will automatically return to its original position after 15 seconds of being idle.
  8. Check if there are any shared users adjusting the camera.
    1. Navigate to the camera’s settings > Sharing.
    2. Temporarily remove shared users, if needed.
  9. Power cycle Wyze Duo Cam Pan.
    1. Unplug the camera from its power source for 5-10 seconds, then plug it back in.
  10. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera as new.
