My Wyze Duo Cam Pan is not turning on.
Problem
Your Wyze Duo Cam Pan won’t power on or doesn’t have a status light.
Troubleshooting
  1. Make sure that the camera is powered using the power cable and adapter that came with the camera.
  2. Ensure the power cable is inserted correctly and securely into the camera.
    • Wyze Duo Cam Pan uses a USB-C power cable.
    • Wyze Duo Cam Pan’s power port is on the back of the bottom camera.
  3. Press and hold the setup button until you hear “ready to connect”.
  4. Try plugging the camera into a different power outlet.
  5. If the camera still does not power on, try another power cable or adapter to determine if the cable or adapter is defective.
