My Wyze Cam Pan v4 is panning to a different location.
Problem
When I adjust the direction of my Wyze Cam Pan v4 through the Wyze app, it moves back to its original position after a few seconds.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Cam Pan v4’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Turn off Smart Track.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Smart Track.
    2. Tap to turn it on/off.
      • The icon will be grey when turned off.
  4. Turn off Pan Scan.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Pan Scan.
  5. Disable any Detection Zone.
    1. In the camera’s settings, tap Detection Settings > Detection Zone.
    2. Toggle off Detection Zone.
      • Note: If the camera’s view is adjusted while a Detection Zone is enabled, the camera will automatically return to its original position after 15 seconds of being idle.
  6. Adjust the Waypoints.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Pan Control.
      • If Pan Control was already selected, that button will change to Events, and there will be a directional pad on the screen to adjust the camera’s position.
    2. Tap the pencil icon to edit existing Waypoints.
    3. Remove any existing Waypoints, and add them back one at a time, testing between each one.
      • Note: The Home Waypoint cannot be deleted, but can be updated to change its position.
  7. Calibrate the camera.
    1. In the camera’s settings, tap Pan Controls.
    2. Next to Calibrate Position, tap Calibrate.
    3. Wait for the calibration to complete before exiting that screen.
    4. Note: Ensure there is nothing impairing the camera’s ability to move, including the power cable.
  8. Check if there are any shared users adjusting the camera.
    1. Navigate to the camera’s settings > Sharing.
    2. Temporarily remove shared users, if needed.
  9. Power cycle Wyze Cam Pan v4.
    1. Unplug the camera from its power source for 5-10 seconds, then plug it back in.
  10. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10-20 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera as new.
