Problem
Your Wyze Cam Pan v4 is unable to be set up.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- Check that the camera’s status light is flashing red and that there is a “ready to connect” voice prompt after pressing the setup button.
- The status light for Wyze Cam Pan v4 is on the front of the camera.
- If the camera status light is solid red, refer to My Wyze Cam Pan v4’s status light is solid red.
- If the camera does not show a status light or there is no voice prompt, refer to My Wyze Cam Pan v4 is not turning on.
- Ensure that BluetoothⓇ is enabled for the Wyze app in the phone/tablet settings.
- Toggle BluetoothⓇ off/on.
- Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
- Make sure that it is set to Always or While Using the App.
- For iOS users, make sure that Precise Location is turned on.
- If possible, temporarily disable any VPNs on the mobile device or Wi-Fi router.
- Ensure that the phone/tablet is connected to the same Wi-Fi network that is being entered at the Select your network step, that the SSID (Wi-Fi name) is being entered correctly, and that the network is functioning normally.
- Wyze Cam Pan v4 is compatible with both 2.4 GHz and 5 GHz Wi-Fi networks.
- The SSID is case-sensitive, and there should be no space before or after the SSID.
- The SSID should automatically populate if the phone/tablet is connected to Wi-Fi. If it does not auto-populate, it can indicate that the phone/tablet that is being used for setup is not connected to Wi-Fi.
- Check that the Wi-Fi password is entered correctly.
- Tap on the eye icon to view the password entered.
- Make sure the camera and phone/tablet are close to the router (within 6-10 feet) during the setup process.
- Forget the Wi-Fi network and rejoin the network on the phone/tablet, then try setting up the camera again.
- Reboot the Wi-Fi router.
- Power cycle Wyze Cam Pan v4.
- Unplug the camera from its power source for 5-10 seconds, then plug it back in.
- Factory reset the camera and then set it up as new.
- Remove any microSD card that is inserted into the camera.
- With the camera powered on, press and hold the setup button on the bottom of the camera for 10-20 seconds until the status light on the front of the camera turns solid red.
- Single-pressing the SETUP button will not reset your Wyze Cam Pan v4. You must press and hold the SETUP button for 10-20 seconds, until the status light turns red, to reset the device.
- Once the status light starts flashing red, set up the camera as new.
What happens when you factory reset your Wyze Cam Pan v4:
The device settings and previous Wi-Fi/setup state are cleared.
The current firmware version remains intact.
The camera must be set up as a new device before it can be used again.
