Problem
Your Wyze Cam Pan v4 won’t power on or doesn’t have a status light.
Troubleshooting
- Make sure that the camera is powered using the power cable and adapter that came with the camera.
- Ensure the power cable is inserted correctly and securely into the camera.
- Wyze Cam Pan v4 uses a USB-C power cable.
- Wyze Cam Pan v4’s power port is on the side of the camera’s base.
- Press and hold the setup button until you hear “ready to connect”.
- Try plugging the camera into a different power outlet.
- If the camera still does not power on, try another power cable or adapter to determine if the cable or adapter is defective.
Note: Wyze Cam Pan v4 requires a 5V 2A power adapter.
