I can’t turn Privacy Mode off on my Wyze Cam Pan v4.
Problem
Your Wyze Cam Pan v4 is currently in Privacy Mode. When you try to exit, it stays in Privacy Mode. You tap Privacy Mode in the app, but nothing happens.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Cam Pan v4’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure there is nothing blocking the camera’s ability to move.
  4. Calibrate the camera.
    1. In the camera’s settings, tap Pan Controls.
    2. Next to Calibrate Position, tap Calibrate.
    3. Wait for the calibration to complete before exiting that screen.
    4. Note: Ensure there is nothing impairing the camera’s ability to move, including the power cable.
  5. Power cycle Wyze Cam Pan v4.
    1. Unplug the camera from its power source for 5-10 seconds, then plug it back in.
  6. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10-20 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera as new.
