How do I lock Wyze Palm Lock?
There are 5 ways to lock Wyze Palm Lock:
  • Auto-Lock
  • Touchscreen
  • Wyze app
  • Integrations
  • Physical Keys
Auto-Lock
Wyze Palm Lock can lock automatically when the door is closed.
In the Wyze app, tap on your Wyze Palm Lock then the Settings gear and Auto-Lock.
On the Auto-Lock screen, you can:
  • Toggle On/Off Auto-Lock.
  • Choose Immediately if you want the door to lock when the door is closed.
  • Choose After a Delay if you want the door to lock after a set amount of time.
    • You can set the delay from 15 seconds to 15 minutes and 30 seconds.
Touchscreen
Wyze Palm Lock has a touchscreen that will light up when a person is detected, or when the screen is tapped.
You can use the touchscreen to tap the lock icon to lock the door.
Wyze App
The Wyze app lets you control your Wyze Palm Lock from anywhere, so you can lock it from anywhere, too.
In the Wyze app, tap on your Wyze Palm Lock and tap the Unlocked lock icon.
Integrations
Wyze Palm Lock is connected to Wi-Fi, which means you can use your smart assistants like Alexa or Google Assistant to lock your door. Simply command it to lock.
"Alexa, lock [Palm Lock name]."
"Hey Google, lock [Palm Lock name]."
Physical Keys
Wyze Palm Lock comes with two physical keys so you can lock the door the old fashioned way.
