How much sunlight does Wyze Solar Cam Pan need?
At least 1 hour of direct sunlight per day.
Wyze Solar Cam Pan's high-efficiency ETFE solar panel is designed for maintenance-free performance*.
For continuous power, Wyze Solar Cam Pan needs about 1 hour of direct sunlight per day. This allows the solar panel to generate enough energy to keep the camera running under normal usage conditions. Be sure to install the camera where it can receive unobstructed sunlight each day, and avoid pointing your camera at swaying trees, bushes, busy roads, as this may drain your battery quickly.
*Actual performance may vary depending on local sunlight intensity, seasonal changes, camera settings, and event activity levels.
