What are the mounting options for Wyze Solar Cam Pan?
Mounting the Camera
You can either mount Wyze Solar Cam Pan's camera on a vertical wall or under an eave using the included camera mounting bracket and mounting kits. Make sure that there is at least 2 inches of clearance around the camera. Do not mount on an angled wall.
Mounting the Solar Panel
You can mount the solar panel directly on top of the camera, or mount the solar panel separately. Use the included 10-ft cable to connect the solar panel, ensuring it's mounted in an optimal position where it receives enough direct sunlight
