Is your Wyze Solar Cam Pan 2K moving too slow or fast for you? Change the pan/tilt speed in your Settings > Pan Controls.
To change the rotation speed:
- In the Wyze app, tap on your Wyze Solar Cam Pan 2K.
- Tap on the Settings gear, then Pan Controls.
- Tap Slow, Normal, or Fast under Manual Rotate Speed.
