The “2K” name and packaging update help clearly distinguish the updated version from earlier Wyze Solar Cam Pan units. If you purchase Wyze Solar Cam Pan 2K from Wyze after April 03, 2026, you are purchasing the updated version.
- If I am unsure which version I have, how can I tell?
- I already own the earlier Wyze Solar Cam Pan. How do I know if mine is affected by the recall?
- What should I do before installing Wyze Solar Cam Pan 2K?
- Which screws should I use to attach the solar panel to the top of Wyze Solar Cam Pan 2K?
- Was the previous issue related to the camera itself or the installation process?
- Why does the packaging say "Wyze Solar Cam Pan 2K"?
- How is Wyze Solar Cam Pan 2K different from the earlier version?
- Is Wyze Solar Cam Pan 2K part of the previous Wyze Solar Cam Pan recall?
- Wyze Solar Cam Pan Security Camera Voluntary Recall
- Is Wyze Solar Cam Pan 2K's battery removable?
- See more
