No, the battery is built-in and non-removable.
The rechargeable battery in your Wyze Solar Cam Pan 2K is built-in, and cannot be removed. To charge it (which you'll rarely need to do) simply plug the camera into 5V/2A power.
Note: The battery pack from Wyze Battery Cam Pro is not compatible with Wyze Solar Cam Pan 2K.
Wyze Solar Cam Pan 2K comes with an integrated solar panel that works really well. You can say goodbye to battery swaps and downtime spent charging. Hooray!
