Does Wyze Solar Cam Pan work with Wyze Solar Panel?
No, Wyze Solar Cam Pan only works with the included solar panel.
Wyze Solar Cam Pan comes with its own integrated solar panel that can be mounted to the device, or separately. It does not work with other solar panel devices.
Wyze Solar Panel only works with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro. While it can be used with Wyze Solar Cam Pan backup charging purposes only, it does not support data transmission and will not show on the Power Manager page.
