My Wyze Solar Cam Pan has a laggy live stream.
Note: You'll need to be on Wyze app version 3.14 or above in order to set up or reconnect your Wyze Solar Cam Pan.
Problem
Your Wyze Solar Cam Pan has a choppy or laggy live stream.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Solar Cam Pan’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure Wyze Solar Cam Pan has good signal strength.
    1. You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
    2. If it has 2 bars or less, try moving the camera closer to the router.
  4. Switch between using the Wi-Fi connection and cellular/mobile data to determine if there is an issue with the Wi-Fi.
  5. Force close and reopen the Wyze app.
  6. Adjust the live stream resolution to a lower resolution.
    • Higher resolution requires more bandwidth and is more likely to cause slower connectivity.
  7. Adjust the camera’s speed.
    1. In the camera’s settings, select Pan Controls.
    2. Under Manual Pan-Tilt Speed, adjust the slider to Low.
    3. Note: Faster rotation speeds may cause video lag when the Wi-Fi signal is not optimal.
  8. Reboot the Wi-Fi router.
  9. Restart the camera.
    1. Navigate to the camera’s settings > Restart Camera > Restart.
  10. Factory reset Wyze Solar Cam Pan.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 20-30 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
