Wyze Solar Cam Pan Setup Troubleshooting
Note: You'll need to be on Wyze app version 3.14 or above in order to set up or reconnect your Wyze Solar Cam Pan.
Problem
Your Wyze Solar Cam Pan is unable to be set up.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Check that the camera’s status light is flashing red and that there is a “ready to connect” voice prompt after pressing the setup button.
  3. Ensure that Bluetooth® is enabled for the Wyze app in your phone/tablet settings.
    1. Toggle Bluetooth® off/on.
  4. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  5. If possible, temporarily disable any VPNs on the mobile device or Wi-Fi router.
  6. Ensure that the phone/tablet is connected to the same Wi-Fi network that is being entered at the Select your network step, that the SSID (Wi-Fi name) is being entered correctly, and that the network is functioning normally.
    • Wyze Solar Cam Pan is only compatible with 2.4 GHz Wi-Fi networks.
    • The SSID is case-sensitive, and there should be no space before or after the SSID.
    • The SSID should automatically populate if the phone/tablet is connected to Wi-Fi. If it does not auto-populate, it can indicate that the phone/tablet that is being used for setup is not connected to Wi-Fi.
  7. Check that the Wi-Fi password is entered correctly.
    1. Tap on the eye icon to view the password entered.
  8. Make sure the camera and phone/tablet are close to the router (within 6-10 feet) during the setup process.
  9. Forget the Wi-Fi network and rejoin the network on the phone/tablet, then try setting up the camera again.
  10. Reboot the Wi-Fi router.
  11. Factory reset Wyze Solar Cam Pan.
    1. Remove any microSD card that is inserted into the camera.
    2. Press and hold the setup button for 20-30 seconds.
    3. Once the status light starts flashing red, set up the camera as new.
