This article details how to set up your Wyze Battery Video Doorbell. Let's get started!
To set up your Wyze Battery Video Doorbell:
- In the Wyze app, tap Home, then tap + plus sign on the top right.
On the Add menu, tap Device.
- If Bluetooth is enabled, your camera may be found automatically. Tap Set Up to pair.
- Tap Cameras > Video Doorbells > Wyze Battery Video Doorbell.
- Press and hold the SETUP button on the back of the doorbell for 5 seconds until the status light flashes red and it says "ready to connect."
- In the app, tap "I heard “Ready to connect," then Begin Setup.
- If you haven’t already enabled Bluetooth® and location access for the Wyze app, there will be a screen prompting you to do so. Once enabled, tap Next.
- If Bluetooth® and location access have already been enabled, it will skip to the next step.
- The app will automatically begin searching for and pairing with your Wyze Battery Video Doorbell.
- If you have multiple Wyze Battery Video Doorbells, select the correct camera by tapping the MAC address that matches the address on the back of the doorbell.
- Select your 2.4 GHz network and enter your network password. Tap Connect.
- Tap the icon in the password field to display the password to ensure it was entered correctly.
- Your device will continue pairing. Once paired, tap Next.
- Follow the in-app instructions to mount Wyze Battery Video Doorbell.
- Also handy: Wyze Battery Video Doorbell Installation Guide.
- Choose your chime option, then tap Next.
- By Itself. The doorbell will ring when it's pressed.
With an existing house chime. Your doorbell will ring on your house chime, using Wyze Chime Controller (sold separately) when pressed.
- You'll be prompted to set up Wyze Chime Controller after doorbell setup is complete.
With a Wyze Wi-Fi Chime. Your doorbell will ring on a Wyze Wi-Fi Chime (sold separately) when it is pressed.
- You'll be prompted to set up Wyze Wi-Fi Chime after doorbell setup is complete.
- You've successfully set up your Wyze Battery Video Doorbell. Now it's time to customize it. Tap Next.
- Name your Wyze Battery Video Doorbell using the text field, or by choosing a suggestion. Tap Finish when done.
- You may have a prompt to enable Cam Plus. Tap Continue.
- Set up some automations on the Things to Try* page, or tap Skip.
- You’re all set! Your doorbell is set up and ready to go.
