Wyze Battery Video Doorbell Tech Specs
Wyze Battery Video Doorbell Device Details
  • Color: Black
  • Finish: Glossy
  • Dimensions: 5.71 in x 1.85 in x 1.14 in (145 mm × 47 mm × 29 mm)
  • Weight: 7.58 oz (215 g)
  • Materials:
    • Body: Polycarbonate
    • Lens: Glass
Power
  • Battery-Powered (Recommended)
    • Battery: 6400 mAh, non-removable, Lithium-ion battery
    • Charging Time: 0-100% in 6 hours
    • Battery Life: Up to 3-6 months with normal use
    • Cable: USB-C to USB-A
    • Adapter: 5V2A (not included)
  • Hardwired
    • Power Requirement: 12-24V, 50/60HZ AC
Video
  • Resolution: 1536 x 1536 HD+
  • Field of View: 180º diagonal, 148º horizontal, 148º vertical
  • Digital Zoom: 8x
  • Frame Rate:
    • Daytime: 20 FPS
    • Nighttime: 15 FPS
Night Vision
  • Color Night Vision
  • 850nm IR Lights
Audio
  • Microphone: Built-in, digital
  • 2-Way Audio, simultaneous
  • Pre-made responses
  • Siren: 90 dB
Alerts
  • Push notifications
  • Motion Warning
Storage
  • Cloud Storage
    • Stored in the AWS Cloud (Wyze Service subscription required)
  • Local Storage
    • Supports 8-32 GB microSD cards in FAT32 format
    • Supports up to 256 GB microSD cards in exFAT format
Connectivity
  • Wi-Fi: 802.11 b/g/n 2.4 GHz, Wi-Fi 4/5/6
  • Bluetooth®: BLE 5.0
Integrations
  • Amazon Alexa, Google Assistant, and IFTTT
Supported Wyze Services
  • Cam Plus
  • Wyze Web View
Chime Compatibility
Phone Compatibility
  • Supports Android 10.0+ and iOS 16.0+
Temperatures
  • Operating Temperature: -4 to 122°F (-20 to 50°C)
  • Storage Temperature: -4°F - 140°F (-20°C - 60°C)
Weather Resistance
  • Indoor and outdoor (IP65)
Language
  • English
Warranty
  • 1-Year
