Introducing Wyze Light Strip
Wyze Light Strip and Wyze Light Strip Pro are built to add color to every corner of your home and brighten up your life.
Features that Wyze Light Strip and Wyze Light Strip Pro share:
  • 16 million colors: Explore all the colors of the rainbow or different shades of white.
  • Sync to the music: Sync your lights to the beat of the music with a built-in microphone for an immersive experience.
  • Sun Match: Automatically adjust the color temperature of your strips to match the time of day.
  • Scenes: Group strips together and explore default scenes or save your own to match your mood.
  • Trimmable Design: Simply cut the strip at a designated marks to make it fit any location.
  • Timers: Set a timer to turn your device on or off.
  • Vacation Mode: Have Wyze Light Strip automatically turn on and off to make it look like someone is home.
  • Sleep Routines: Set Wyze Light Strip to gently turn on in the morning to help you wake up or fade out in the evening to help you fall asleep.
  • Wi-Fi App Control: Control your lights directly from the controller on the strip or from anywhere in the world with the Wyze app.
  • Easy Setup: Peel and stick directly onto your desired location and use the optional clips for extra strength. You can pair multiple devices to the Wyze App at the same time for a quick and easy setup.
  • Voice Control: Use Alexa or Google Assistant to control your Wyze Light Strips by voice.
Benefits of Wyze Light Strip Pro
  • Individual Segment Control: Wyze Light Strip Pro has 16 independently controlled segments so you can set multiple colors at the same time on one strip for even more unique ambiances.
  • Advanced Lighting Effects: Individual sections of Wyze Light Strip Pro can turn on and off allowing for a variety of fun and advanced lighting effects.
  • Protective Epoxy Coating: A clear epoxy coating adds extra durability and a more refined appearance.
Still need help?
