Wyze Light Strip (and Pro) Setup Guide
To set up your Wyze Light Strip:
  2. On the Add menu, tap Device.
  3. Tap Power & Lighting > Wyze Light Strip or Wyze Light Strip Pro.
    • Pro Tip: You can set up both versions from the same option. It doesn’t matter which you select.
  4. Follow the in-app instructions to install your light strip and controller in your desired location.
  5. Plug the power adapter into a nearby outlet and see the light strip begin to pulse, showing it’s in pairing mode.
    1. Want to set up several light strips at once? Install, and power them on now.
      • You can set up a lot of strips at once. We've tested over 30!
    2. The light strip(s) will automatically begin to pulse.
    3. Not pulsing? Press and hold the side button on the controller for 7 seconds to put it into pairing mode.
  6. If prompted by the Wyze app, allow access to your location and BluetoothⓇ. Tap OK.
  7. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
  8. On the next screen, you'll see your light strips(s) connecting to the network.
  9. Once connected, name your light(s) and edit the icon(s).
    1. Tap on the light strip name, then type in the pop-up to edit. Tap Next.
      • If you're setting up multiple light strips, they will each glow a specific color during setup. Name each one accordingly.
  10. You’re all set. Enjoy your new Wyze device!
