Changing Colors on Wyze Light Strip (and Pro)
Changing Colors
You are able to easily change the color or color-temperature of both Wyze Light Strip and Wyze Light Strip Pro. From the Wyze app, simply tap on the light strip or group you’d like to control. On the Design tab you will see the color wheel which you can use to adjust the color of your light strips. Swipe from right to the left of the screen to get to the white color-temperature wheel which allows you to find the perfect shade of white.
