Creating and Editing Scenes on Wyze Light Strip (and Pro)
Scenes allow you to quickly set all the lights in your room to the perfect setting. To create your own Scenes, first adjust your lights on the Design tab to your desired setting. Next, tap the Scenes tab, then Edit, and then click on the large “+” card. To save your Scene, give it a name and tap ‘OK’.
