How to Clean the Rolling Brush
During regular maintenance, the motorized brush should also be cleaned to reduce the chance of clogging.
  1. Remove any attachments by pressing the release key.
  2. Press the brush release button, then pull to remove the brush.
  3. Run a razor blade down the groove to break up any hair or debris as necessary, then clean any that remain.
  4. Slide the brush back into the housing until it clicks back into place.
