Low/Dead Battery for the Wyze Leak Sensor/Leak Sensor Probe
Problem: The sensor battery was dead on arrival; the sensor battery is low or has drained faster than expected
Troubleshooting:
  • Check if the sensor light flashes red three times when pressed.
    • If it does not flash three times, open the battery compartment, remove the battery and reinsert it again.
    • Press the reset button again and check if the light flashes.
  • Try replacing the battery.
If these steps do not resolve the issue, please reach out to our support team so we may assist you.
