Wyze Cam Pan v2 Setup Guide
Before you begin setup:
  3. Unpack your Wyze Cam Pan v2 box, removing all plastic and packing materials.
  4. Plug the camera into power using the included USB cable and power adapter.
    • The camera’s status light will turn solid red when powered. When flashing, it’s ready for setup.
To set up your Wyze Cam Pan v2:
  2. On the Add menu, tap Device.
  3. Tap Cameras > Pan and Tilt Camera > Wyze Cam Pan v2.
  5. On the bottom of your camera, single-press SETUP under the camera. It will say “ready to connect”.
  6. In the app, check the box next to I heard, “Ready to connect”.
  7. Tap Next.
  8. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  9. Scan the QR code on the Wyze app.
    • Hold your camera up to your phone screen with the QR code displaying. It will say “QR code scanned, please wait” then “setup completed”.
  10. In the app, check the box next to I heard, “QR code scanned”.
  11. After the camera is set up and connected, it will say "setup completed".
  12. Tap Next. You’re set up, it’s time to name your device.
  13. Name your Wyze Cam Pan v2 using the text field, or by choosing a suggestion.
  14. Tap Finish when done.
  15. You may have a prompt for a free trial of Cam Plus. Tap Continue.
  16. Set up some automations on the Things to Try* page, or tap Skip.
  17. You’re all set. Enjoy your new Wyze device!
Things to Try: Tap Add your device to a group, Share this device, Automate your device, or Skip. These are quick ways to set up a few automations before you finish setup. When you complete a task, it'll display a green checkmark ✅. You can move on from this page by tapping Skip.
Additional Notes:
  • Wyze Cam Pan v2 only works on 2.4 GHz Wi-Fi networks. If you are connected to a 5 GHz network, switch to a 2.4 GHz network before setting up your device.
  • Having trouble scanning your QR code? A few tips to help:
    • Hold your camera 6-10 inches away from your phone screen.
    • Slowly move the QR code on the screen away from the camera, then closer.
    • Tilt your phone screen slightly in case there's a glare.
    • Turn your phone upside down.
    • If you're on iOS, turn off "Invert Colors".
    • Make sure the QR code isn't distorted.
      • If you have an older device, the screen may be too small. Try a different device.
      • If your screen is cracked or scratched, the code may be distorted. Try a different device.
      • If you're using a beta version of the Wyze app, make sure the cursor is not on the QR code.
