Wyze Cam Pan v2 Tech Specs
Wyze Cam Pan v2 Device Details
Color: White
Finish: Matte
Camera Dimensions: 127.5 mm (H) x 60 mm (W) x 60 mm (D)
Camera Weight: 8.78 oz (249 g)
Powering Methods
Ports: 1 micro USB
Power Cable Length: 6 feet (1.8 m)
Power Adapter Input: 110-240V (AC/DC)
Power Adapter Output: 5V/2000mA
Mounting Features
Base Screw Hole: 1/4″ – 20
CPU
1.5 GHz
Memory
128 Mb
Audio & Video
Resolution: 1920 X 1080 (1080p)
Camera
Lens: F1.6 aperture, 3.2mm focal length
Image Sensor: 1/2.9'' CMOS
Digital zoom: 8x
Field of View: 120° lens
View Range: 360° horizontal, 93° vertical
Night Vision
6 IR LEDs (940 nm)
Illuminates up to 29.6 feet (9 m)
Video
H.264 encoding
Day time video: 20 FPS
Night vision: 15 FPS
Audio
Built-in speaker and microphone
Class-D power amplifier
Rotation Speed
Up to 110° per second
Alerts
Push notifications
Storage
Cloud Storage
Stored in the AWS Cloud
Local Storage
Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
Supports up to 256 GB microSD cards in exFAT format
Data Security
End-to-end encryption
HTTPS secure transfer protocol
AES 128-bit encryption
Data Usage
1-2 MB per minute in SD, or 4-7 MB per minute in HD
Connectivity
2.4 GHz Wi-Fi
802.11 b/g/n 2.4 GHz (Does not support 5 GHz network)
Supports WPA and WPA2 protocols
Connectivity Requirements
Upload speed is 1.0 Mbps for SD and 1.5 Mbps for HD
Integrations
IFTTT (Available)
Alexa and Google Home (Pending Certification)
Phone Compatibility
Supports iOS 14.0 and Android 7.0 or later
Operating Temperature
32℉ – 104℉ / 0°C – 40 °C
Operating Humidity
<90% at 104℉ / 40°C
Weather Resistance
Indoor use only
Languages
English
Warranty
1-Year
