Understanding your Wyze Cam Pan v2 Status Light
All Wyze devices have a handy status light that helps determine what state the device is in. You'll find the status light on the front of your Wyze Cam Pan v2. No light? Make sure it's properly connected to power.
Wyze Cam Pan v2 Status Light Guide
  • Solid red light - The camera is powered and starting up.
  • Flashing red light - Ready to connect to Wi-Fi.
  • Flashing red and blue lights - Connection is in progress.
  • Flashing blue light - The camera is connected and finishing setup.
  • Solid blue light - Camera is powered, connected, and working properly.
To turn on/off the status light:
  1. In the Wyze app, tap on your Wyze Cam device.
  2. Tap on the Settings gear > Advanced Settings.
  3. Tap the toggle next to Camera Status Light.
You can turn off the status light on all Wyze Cam and video doorbell devices except Wyze Video Doorbell Pro.
Status Light Guide Detailed
  • Solid red light
    •  Camera is powered and starting up
    • Watching live stream
    • Recording alarm video
    • Camera is powered and ready to connect to Wi-Fi
    • Siren is sounding (quick flashing red light)
    • Or, possible error state:
      • QR code incorrect
      • Connection timed out, cannot connect to network
      • Network encryption method not supported
    • Camera is trying to connect to Wi-Fi
    • Scanning QR code
    • Upgrading with a microSD card
      • Network disconnected
    • Camera is connected, still finishing setup
    • Firmware update (quick flashing blue light)
      • Disconnected from external/network server
  • Solid blue light
    • Camera is powered, connected, and working properly
