Is this compatible with 3-way and 4-way switches?
No, this is a single-pole switch only.
Wyze Switch can only replace a switch that is the only switch that controls the fixture. It cannot be used as a multi-way switch.
Examples:
A switch that turns on/off the light in a room. There are no other switches that can also turn that light on or off. If you have neutral wiring, then this switch is compatible.
A switch that turns on/off the light from the bottom of a staircase. There's another switch at the top of the stairs that can also turn that light on or off. This switch is not compatible.
Your switch turns on/off the lights from a panel at the entrance of a room. On the other side of the room, there is another panel that can also turn the lights on/off. This switch is not compatible.
