No, Wyze Switch only comes in white.
- Will Wyze Switch work with aluminum wires?
- Can Wyze Switch be used as a dimmer?
- Does Wyze Switch come in different colors?
- What is the response time for Wyze Switch?
- Is this compatible with 3-way and 4-way switches?
- How long does it take to install Wyze Switch?
- My Wyze Switch won't turn on.
- How do I know if I have a neutral wire?
- How do I check my ground wire?
- Is my wiring compatible with Wyze Switch?
- See more
