Can I set a schedule for Wyze Cam Floodlight?
Yes, using Automations in the Wyze app.
To create a schedule in the app for Wyze Cam Floodlight:
  2. On the Add menu, tap Automation > Schedule.
  3. Tap Name (Optional).
    1. Enter a name for the schedule. Try "At work."
    2. Tap Save.
  4. Tap Add Action, then your Wyze Cam Floodlight.
    1. Select the action you want, then Save.
  5. Tap Start Time.
    • Select 9:00 AM, then Save.
  6. Tap End Time.
    • Select 5:00 PM, then Save.
  7. Tap the days you want this automation active for. By default, it'll be active every day.
  8. When finished, tap Save.
