What is the siren on Wyze Cam Floodlight and how does it work?
The siren is a really loud, 105 dB speaker.
Wyze Cam Floodlight has a customized speaker inside that it can be used as a siren. It's so loud that you can use it to ward off intruders. Control the Siren feature from the Wyze app under the Live stream, or by using Automations.
