The pre-installed cam controls the floodlight.
The main Wyze Cam v3 that comes pre-installed controls the floodlight and its settings. This includes turning it on or off manually or using automatic features like motion detection or Rules.
If you add another camera using the second USB port, that camera will work as a normal Wyze Cam v3 without controlling the floodlight.
